Zum Hauptinhalt wechseln
Dell Inspiron 910 Solid-State Drive (SSD) Replacement
Was du brauchst
  1. Dell Inspiron 910 Solid-State Drive (SSD) Replacement, Remove screws from SSD: Schritt 1, Bild 1 von 1
    • "CAUTION"If you remove the solid-state drive from the computer when the drive is hot, do not touch the solid-state drive
    • Remove the two screws that secure the solid-state drive.
    • Lift the solid-state drive out of its system board connector.
    • Insert the solid-state drive into the slot at a 45-degree angle.
    • Press the solid-state drive down and replace the two screws that secure the drive.
    • Replace the module cover
    • Slide the battery into the battery bay, until it clicks into place and slide the battery-lock latch towards the lock position.
    • Make sure to replace all screws and ensure that there are no stray bolts.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Devyn Johnson
232 Reputation
2 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
43 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 7
Insgesamt: 716
