Einleitung
This guide will teach you how to remove the buttons below the track pad from the laptop device.
Was du brauchst
Flip the laptop so the battery is facing upwards.
Push the battery release tabs toward the center of the device.
Remove the battery.
Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
Lift up the keyboard using your fingers or a plastic opening tool.
Disconnect the cable by sliding the connector ears outward.
Remove the seven Phillips #00 screws that hold the metal component to the frame
Detach the two ribbon cables on either side of the silver panel
Gently lift the silver panel from the laptop using the plastic opening tool
Set the laptop aside
Flip the silver panel over
Remove the four screws that connect the buttons to the panel using the Phillips #00 Screwdriver
Remove the covers from the panel
Remove the buttons from the panel
Release the mouse button by flipping the center connector tab up
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
