Zum Hauptinhalt wechseln
Dell Inspiron 910 Touchpad Buttons Replacement
Was du brauchst
  1. Dell Inspiron 910 Touchpad Buttons Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Touchpad Buttons Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Touchpad Buttons Replacement: Schritt 3, Bild 1 von 1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Touchpad Buttons Replacement, Touchpad Buttons: Schritt 4, Bild 1 von 1
    • Remove the seven Phillips #00 screws that hold the metal component to the frame
    • Detach the two ribbon cables on either side of the silver panel
    • Be careful to not tear the ribbon cables hidden behind the panel
    • Gently lift the silver panel from the laptop using the plastic opening tool
    • Set the laptop aside
    • depending on your model, there could still be some hidden screws on the bottom of the case of the mini that hold the palm-rest in place
  5. Dell Inspiron 910 Touchpad Buttons Replacement: Schritt 5, Bild 1 von 1
    • Flip the silver panel over
    • Remove the four screws that connect the buttons to the panel using the Phillips #00 Screwdriver
  6. Dell Inspiron 910 Touchpad Buttons Replacement: Schritt 6, Bild 1 von 1
    • Remove the covers from the panel
    • Remove the buttons from the panel
    • Release the mouse button by flipping the center connector tab up
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kyle Beekman
144 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-10, Forte Spring 2012 Mitglied von Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,173
