Zum Hauptinhalt wechseln
Dell Inspiron 9100 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 9100 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 9100 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 9100 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Keyboard Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Turn the laptop around.
  4. Dell Inspiron 9100 Keyboard Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
    • Fold the screen back to 180 degrees.
    • Using your index fingers, pull up the hinge cover.
  5. Dell Inspiron 9100 Keyboard Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • After the hinges pop, pull the hinge cover gently.
    • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
  6. Dell Inspiron 9100 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  7. Dell Inspiron 9100 Keyboard Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 9100 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Tilt the keyboard away from the screen.
    • Pull up on the white tab underneath the keyboard to release the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ana
111 Reputation
1 Anleitung geschrieben
Cal Poly, Team 13-2, Forte Winter 2011 Mitglied von Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 16
Insgesamt: 4,014
