Einleitung
This guide requires a Phillips #00 screwdriver
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Unplug the laptop from the power adapter and turn the power off. Failure to unplug laptop before proceeding could result in risk of electric shock! Failure to unplug laptop before proceeding could result in risk of electric shock!
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Slide the battery-lock tab and hold. Flip the battery away from the chassis to remove it. Flip the battery away from the chassis to remove it.
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Undo the screw on the Mini-PCI card cover labeled "C" This screw will remain within the panel
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  5. Disconnect the antenna cables from the Mini-PCI card.
    • Disconnect the antenna cables from the Mini-PCI card.
  6. Use your fingertips to carefully spread apart the white plastic tabs. Flip the Mini-PCI card up at a 45 degree angle. Remove the card from the computer by sliding out diagonally
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
charlierefvem
854 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 13-2, Forte Winter 2011 Mitglied von Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Mitglieder
8 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 4,003
