Zum Hauptinhalt wechseln
Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement
Was du brauchst
  1. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Battery: Schritt 1, Bild 3 von 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: Schritt 2, Bild 3 von 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: Schritt 3, Bild 1 von 2 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement, Mini-PCI (WiFi) Card: Schritt 3, Bild 2 von 2
    • Undo the screw on the Mini-PCI card cover labeled "C"
    • This screw will remain within the panel
    • Remove the panel from the chassis.
  4. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the antenna cables from the Mini-PCI card.
  5. Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 9100 Mini-PCI (WiFi) Card Replacement: Schritt 5, Bild 3 von 3
    • Use your fingertips to carefully spread apart the white plastic tabs.
    • Flip the Mini-PCI card up at a 45 degree angle.
    • Remove the card from the computer by sliding out diagonally
    • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
charlierefvem
854 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 13-2, Forte Winter 2011 Mitglied von Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 20
Insgesamt: 4,335
