Zum Hauptinhalt wechseln
Dell Inspiron 9300 Trackpad Replacement
Was du brauchst
  1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: Schritt 1, Bild 1 von 1
    • Remove the battery in to order avoid damaging internal components.
  2. Dell Inspiron 9300 Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
  3. Dell Inspiron 9300 Trackpad Replacement: Schritt 3, Bild 1 von 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • There is a notch on the right-hand side of the bezel for easiest removal.
  4. Dell Inspiron 9300 Trackpad Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 9300 Trackpad Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 9300 Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward, away from the motherboard.
  5. Dell Inspiron 9300 Trackpad Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 9300 Trackpad Replacement: Schritt 5, Bild 2 von 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  6. Dell Inspiron 9300 Trackpad Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 9300 Trackpad Replacement: Schritt 6, Bild 2 von 2
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
  7. Dell Inspiron 9300 Trackpad Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 9300 Trackpad Replacement: Schritt 7, Bild 2 von 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
  8. Dell Inspiron 9300 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Pull up and away on the upper case to remove.
Abschluss
USF Tampa, Team 16-6, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 29
Insgesamt: 237
