Zum Hauptinhalt wechseln
Dell Inspiron 9300 Video Card Replacement
Was du brauchst
  1. Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: Schritt 1, Bild 1 von 2 Dell Inspiron 9300 Video Card Replacement, Prerequisite Only: Schritt 1, Bild 2 von 2
    • Remove the battery prior to working on any internal components.
    • Remove the twelve 6mm Phillips screws from the bottom of the case.
    • Remove the battery before working on internal components to ensure a safe working environment.
  2. Dell Inspiron 9300 Video Card Replacement: Schritt 2, Bild 1 von 1
    • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
    • Start on the right hand side, where there is a notch in the bezel for easiest removal.
  3. Dell Inspiron 9300 Video Card Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 9300 Video Card Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 9300 Video Card Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 5mm Phillips screws retaining the keyboard.
    • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
    • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
  4. Dell Inspiron 9300 Video Card Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 9300 Video Card Replacement: Schritt 4, Bild 2 von 2
    • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
    • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
    • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
  5. Dell Inspiron 9300 Video Card Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 9300 Video Card Replacement: Schritt 5, Bild 2 von 2
    • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
    • Gently pry the CMOS battery out of its retaining clip using a spudger.
  6. Dell Inspiron 9300 Video Card Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 9300 Video Card Replacement: Schritt 6, Bild 2 von 2
    • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
    • Remove the trackpad ribbon cable from the motherboard using a spudger.
  7. Dell Inspiron 9300 Video Card Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 9300 Video Card Replacement: Schritt 7, Bild 2 von 2
    • Pull up and away on the track pad to expose the internal components below.
  8. Dell Inspiron 9300 Video Card Replacement, Video Card: Schritt 8, Bild 1 von 1
    • Loosen the four 5mm Phillips screws holding the video card and heatsink in place
    • The screws are held in place with retainer clips and are not fully removable
  9. Dell Inspiron 9300 Video Card Replacement: Schritt 9, Bild 1 von 1
    • Firmly pull up to unseat the video card from the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 16-6, Eyestone Fall 2016 Mitglied von USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
This works only up to the point of pull up and away on the trackpad. The trackpad won't pull up.
cobrachoppergirl - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 871
