Zum Hauptinhalt wechseln
Dell Inspiron 9300 WIFI Card Replacement
Was du brauchst
  1. Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: Schritt 1, Bild 1 von 3 Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: Schritt 1, Bild 2 von 3 Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 WIFI Card Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 9300 WIFI Card Replacement: Schritt 2, Bild 2 von 2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: Schritt 3, Bild 1 von 2 Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: Schritt 3, Bild 2 von 2
    • Gently pry up on the gold antennae connections using a spudger.
    • Gently pry open both retaining clips on either side of the WiFi card using a spudger.
    • Once the clips are open and the card is unplugged, it is safe to remove.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Master Techs Mitglied von Master Techs
Community
327 Mitglieder
1.697 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 458
