Zum Hauptinhalt wechseln
Dell Inspiron B130 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron B130 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron B130 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron B130 Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron B130 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron B130 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron B130 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron B130 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Dell Inspiron B130 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • This particular computer is missing its hard drive.
    • Remove the two screws.
    • Remove the plastic cover by lifting from the groove as indicated.
    • Remove the hard drive from the computer by lifting up and out.
Abschluss
UMass Dartmouth, Team 1-8, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 671
