Zum Hauptinhalt wechseln
Dell Inspiron B130 RAM and Wireless Replacement
Was du brauchst
  1. Dell Inspiron B130 RAM and Wireless Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron B130 RAM and Wireless Replacement, Battery: Schritt 1, Bild 3 von 3
    • First, make sure your computer is turned off.
    • Remove the battery by flipping the two switches under the battery and pulling it out
  2. Dell Inspiron B130 RAM and Wireless Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 2, Bild 3 von 3
    • Push the tab from the battery, downwards to unlock the battery.
    • The tab should be in the position next to the unlocked indicator.
  3. Dell Inspiron B130 RAM and Wireless Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 3, Bild 3 von 3
    • Now, push the other tab (the one right under the battery) from right to left.
    • Now the battery will be loose; lift the battery up and out of the computer.
  4. Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: Schritt 4, Bild 1 von 2 Dell Inspiron B130 RAM and Wireless Replacement, RAM and Wireless: Schritt 4, Bild 2 von 2
    • Remove the three 6mm screws.
    • Lift the plastic cover off to reveal the RAM and the Wireless.
  5. Dell Inspiron B130 RAM and Wireless Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 5, Bild 3 von 3
    • To remove the RAM, push outward against the metal brackets.
    • The first RAM will pop up so you can just pull it right out.
    • Repeat the first step again to remove the second RAM chip.
    • Installation is the reverse of removal.
  6. Dell Inspiron B130 RAM and Wireless Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 6, Bild 2 von 2
    • To remove the wireless chip, push outward on its two metal brackets.
    • Do not remove the chip just yet, the wire that connects this chip must first be removed.
  7. Dell Inspiron B130 RAM and Wireless Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron B130 RAM and Wireless Replacement: Schritt 7, Bild 2 von 2
    • To remove the wire, hold the wireless chip firmly and pull the connection straight up off of the chip.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-8, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-8, Catania Fall 2016
UMASSD-CATANIA-F16S1G8
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 302
