Zum Hauptinhalt wechseln
Dell Inspiron E1505 GPU Replacement
Was du brauchst
  1. Dell Inspiron E1505 GPU Replacement, Battery and Optical drive: Schritt 1, Bild 1 von 3 Dell Inspiron E1505 GPU Replacement, Battery and Optical drive: Schritt 1, Bild 2 von 3 Dell Inspiron E1505 GPU Replacement, Battery and Optical drive: Schritt 1, Bild 3 von 3
    • Make sure to power off the laptop to avoid data loss.
    • Slide the battery disconnect right.
    • Remove the screw for the optical drive.
    • Use a screwdriver to push the optical drive out of the base.
    • Gently pull the drive out when it sticks out far enough.
  2. Dell Inspiron E1505 GPU Replacement, Base Screws: Schritt 2, Bild 1 von 2 Dell Inspiron E1505 GPU Replacement, Base Screws: Schritt 2, Bild 2 von 2
    • Remove all 12 screws on the base of the laptop
    • Remove the 2 screws at the back of the laptop.
  3. Dell Inspiron E1505 GPU Replacement, Power Button panel.: Schritt 3, Bild 1 von 3 Dell Inspiron E1505 GPU Replacement, Power Button panel.: Schritt 3, Bild 2 von 3 Dell Inspiron E1505 GPU Replacement, Power Button panel.: Schritt 3, Bild 3 von 3
    • Rotating the screen to a 180-degree position may make it easier to remove.
    • Use a flat head screwdriver and gently pry at the indentation. It should come open semi-easily.
    • Grab the panel and gently pull it away from the laptop.
    • Be gentle! This piece is an awkward shape and may break easily.
  4. Dell Inspiron E1505 GPU Replacement, Keyboard and display: Schritt 4, Bild 1 von 3 Dell Inspiron E1505 GPU Replacement, Keyboard and display: Schritt 4, Bild 2 von 3 Dell Inspiron E1505 GPU Replacement, Keyboard and display: Schritt 4, Bild 3 von 3
    • Remove the two screws and slide the keyboard toward the display.
    • There is a delicate ribbon cable attached to the bottom of the keyboard. Be careful when removing it.
    • Rotate the latch up toward the trackpad, then carefully remove the ribbon cable.
    • Remove the antenna connectors on the wifi card by pulling up at the part where the cable meets the connector.
    • Unscrew the grounding cable on the display cable. Disconnect the display cable by pulling up on the tab.
    • Remove the last two screws holding the display in. Rotate the display to an upright 90-degree position. Gently pull up to remove the display.
  5. Dell Inspiron E1505 GPU Replacement, Top Panel: Schritt 5, Bild 1 von 3 Dell Inspiron E1505 GPU Replacement, Top Panel: Schritt 5, Bild 2 von 3 Dell Inspiron E1505 GPU Replacement, Top Panel: Schritt 5, Bild 3 von 3
    • Disconnect the ribbon cable from the motherboard
    • Disconnect the lid sensor.
    • Unscrew the last screw holding the top panel in.
    • Lift the panel.
    • There may be clips in the back, slide your finger or a spudger to pry them off.
    • If you can't lift the panel, go back and check if there are any screws on the base holding it.
  6. Dell Inspiron E1505 GPU Replacement, GPU: Schritt 6, Bild 1 von 3 Dell Inspiron E1505 GPU Replacement, GPU: Schritt 6, Bild 2 von 3 Dell Inspiron E1505 GPU Replacement, GPU: Schritt 6, Bild 3 von 3
    • Remove the two screws shown.
    • Use a spudger to pry the GPU and cooler up.
    • To reconnect the gpu, align it and firmly press at the "Press here" label.
    • Be careful when prying on the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
tmg86
654 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 587
