Zum Hauptinhalt wechseln
Dell Inspiron E1705 Battery Replacement
  1. Dell Inspiron E1705 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron E1705 Battery Replacement: Schritt 2, Bild 2 von 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
Abschluss
To replace your battery, follow these instructions in reverse order.
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 22-5, Maness Fall 2010 Mitglied von Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
I think it would be complete if we knew where to buy it as well.
Nobody would read up on changing a battery if he didn’t need one, so you might as well tell him where to get it.
I think that makes sense. However thank you for your effort.
kjanmunkedal - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 4,320
