Zum Hauptinhalt wechseln
Dell Inspiron E1705 RAM Replacement
Was du brauchst
  1. Dell Inspiron E1705 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 RAM Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron E1705 RAM Replacement: Schritt 2, Bild 2 von 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Dell Inspiron E1705 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Turn the computer over, screen closed, so that the underside is showing
    • Locate the two screws as shown and remove them.
    • Use a small phillips head screwdriver
  4. Dell Inspiron E1705 RAM Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron E1705 RAM Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron E1705 RAM Replacement: Schritt 4, Bild 3 von 3
    • Remove plastic cover carefully
    • There will be two RAM sticks as shown
    • Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
  5. Dell Inspiron E1705 RAM Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove old/damaged RAM sticks and replace with new ones.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 22-5, Maness Fall 2010 Mitglied von Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
If upgrading RAM, a black DOS based screen will show stating "the amount of RAM in system has changed", wait 1minute and the computer will beep and prompt for F1 (boot normally) or F2 (run system setup utility). Pressing F2 and waiting some time will allow the computer to reconfigure and then boot into Windows normally.
bejtommywy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 8,184
