Einleitung
There is some disassembly required. You will want to prepare a clean and organized work space for this repair.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Use a spudger or your fingernail to pry out the 6 rubber and 2 plastic pieces on the bezel of the display.
Use a small phillips head screwdriver to remove the 8 screws.
Use a plastic opening tool to carefully pry the plastic cover from the screen mount.
Remove the 4 screws along EACH side of the screen.
8 screws total
Now use the spudger to lift the screen and rotate away from you.
Lift the screen up and out using the spudger tool
Tilt the screen away from you
The screen will be connected by two leads. See picture
Locate the two leads and gently remove them from the screen. They will stay connected to the computer.
Remove the screen carefully.
8 weitere Nutzer haben diese Anleitung absolviert.
