Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Remove Keyboard retaining screw from bottom of laptop.
Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
Lift the keyboard up slightly and push forward in order to release bottom tabs.
Pull the black tab up and then pull left on keyboard plug to release keyboard.
Flip the laptop, so the bottom of the laptop is facing up.
Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
Flip the laptop back over, so that the top of the laptop is facing up.
Open the laptop.
Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
Flip the laptop over so the bottom is facing up.
Remove the indicated 17 6mm Phillips #000 screws on the back of the laptop using the Phillips #000 screwdriver.
Pull the clear tab attached to the hard drive and gently lift up the hard drive to remove it.
Remove the 4 mm Phillips #000 motherboard screws using the Phillips #000 screwdriver.
Remove the 4 indicated 6 mm Phillips #000 front hinge screws with the Phillips #000 screwdriver.
Remove all 4 of the 6 mm Phillips #000 Heatsink screws with the Phillips #000 screwdriver.
Ein weiterer Nutzer hat diese Anleitung absolviert.
