Zum Hauptinhalt wechseln
Dell Inspiron M531R-5535 Fan Replacement
Was du brauchst
  1. Dell Inspiron M531R-5535 Fan Replacement, Fan: Schritt 1, Bild 1 von 3 Dell Inspiron M531R-5535 Fan Replacement, Fan: Schritt 1, Bild 2 von 3 Dell Inspiron M531R-5535 Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Flip the laptop over and unlock the battery.
    • Lift up to remove the battery.
  2. Dell Inspiron M531R-5535 Fan Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 2, Bild 2 von 2
    • Loosen the two Phillips #1 screws to remove the tray.
    • The screws stay in the tray.
  3. Dell Inspiron M531R-5535 Fan Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the 3.6mm Phillips #1 screw.
    • Slide the CD Drive out.
  4. Dell Inspiron M531R-5535 Fan Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 4, Bild 2 von 2
    • Unscrew nine 5.7mm Phillips #1 screws.
    • Unscrew three 5.6mm Phillips #1 screws
    • The three 5.6mm Phillips #1 screws are thinner.
    • Then flip the laptop and open it to see the keyboard.
  5. Dell Inspiron M531R-5535 Fan Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 5, Bild 2 von 2
    • Use a nylon spudger or plastic opening tool to press into the highlighted keyboard latches.
  6. Dell Inspiron M531R-5535 Fan Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron M531R-5535 Fan Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron M531R-5535 Fan Replacement: Schritt 6, Bild 3 von 3
    • Lift up the keyboard.
    • Lift up on the black ZIF tab and pull the keyboard ribbon cable free.
  7. Dell Inspiron M531R-5535 Fan Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the five 5.6mm Phillips #1 screws.
    • Unscrew the two 3.6mm Phillips #1 screws.
  8. Dell Inspiron M531R-5535 Fan Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 8, Bild 2 von 2
    • Disconnect all highlighted cables.
  9. Dell Inspiron M531R-5535 Fan Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron M531R-5535 Fan Replacement: Schritt 9, Bild 2 von 2
    • Using an opening tool, carefully pry open the case from the side.
  10. Dell Inspiron M531R-5535 Fan Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the Phillips #1 screw.
    • Pull the white connector out to disconnect the cables from the motherboard.
    • Pull up on gold connectors (MHF4) to disconnect the cables connecting the WLAN card.
    • Pull up on the white flap and pull out the strip to disconnect the strip from the motherboard.
  11. Dell Inspiron M531R-5535 Fan Replacement: Schritt 11, Bild 1 von 1
    • Flip the motherboard over.
    • Pull the white connector out to disconnect the fan.
    • Lift the fan to remove it from the motherboard.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Tony Chen
310 Reputation
2 Anleitungen geschrieben
CSU Los Angeles, Team 6-5, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 6-5, Adachi Fall 2022
CSULA-ADACHI-F22S6G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 231
