Einleitung
This guide will take you through removing the display. This may be a necessary process if the display is not functioning properly or is broken. The display panel and motherboard are extremely fragile so remember when replacing to handle with care and consider placing onto a towel.
Was du brauchst
Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
Gently pull the touchpad cable off the palm rest bracket.
Lift the rest of the palm rest off the computer base.
Turn over the device and open the display.
Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
Push the clips out on either side of the ribbon cable to release it.
Gently disconnect the ribbon cable by pulling on the clear tab.
Remove the keyboard.
Close the device and turn over.
Remove the five 8mm Phillips 0 screws.
Turn the device over and open the display.
Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
Disconnect the following:
Power button cable
Speaker cable
Power status light cable
Bluetooth cable (if installed)
Remove the following:
Two 4mm Phillips screws securing the motherboard
AC adapter cable
USB and SIM card cable connector
Display cable connector
Carefully lift the motherboard out.
Pull the Mini-Card cables out of the computer base. They slide out from under a few pieces of plastic that secure them to the base.
Remove the two 4 mm Phillips 0 screws that secure the display assembly to the computer base.
Remove the two rubber pads on the display bezel screws using a finger nail, prying tool or Spudger.
There is one on either side.
Using the plastic opening tool gently pry up the inside edge of the display bezel.
Remove the single 3mm Phillips screw securing the camera to the display panel.
Remove the two 4mm Phillips 0 screws that are visible from the top.
Remove the four 3mm Phillips screws on the side of the display panel securing it to the display cover.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the camera cable using tweezers.
Remove the panel connector by pulling on the blue tab on the back of the display panel.
Eine weitere Person hat diese Anleitung absolviert.
