Zum Hauptinhalt wechseln
Dell Inspiron Mini 10 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron Mini 10 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Hard Drive Replacement, Palm Rest: Schritt 3, Bild 1 von 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Hard Drive Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  6. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  7. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  8. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  9. Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: Schritt 9, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement, Hard Drive: Schritt 9, Bild 2 von 2
    • Remove the single 8mm screw attaching the hard-drive cage to the body of the device.
  10. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port until is comes free.
  11. Dell Inspiron Mini 10 Hard Drive Replacement: Schritt 11, Bild 1 von 1
    • Unscrew the four 3mm screws, two on each side of the drive, and slide the drive free from the cage.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Bariso Shuba
270 Reputation
3 Anleitungen geschrieben
UW Tacoma, Team 1-4, Rose Fall 2016 Mitglied von UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 38
Insgesamt: 7,543
