Zum Hauptinhalt wechseln
Dell Inspiron Mini 10 Palm Rest Bracket Replacement
Was du brauchst
  1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 4, Bild 1 von 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 5, Bild 2 von 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 6, Bild 2 von 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  7. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Palm Rest Bracket: Schritt 7, Bild 1 von 1
    • Close the device and turn over.
    • Remove the five 8mm Phillips 0 screws.
  8. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 8, Bild 2 von 2
    • Turn the device over and open the display.
    • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
  9. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 9, Bild 2 von 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
  10. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 10, Bild 2 von 2
    • Remove the four 6mm Philips 0 screws securing the bracket.
  11. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 11, Bild 1 von 3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 11, Bild 2 von 3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 11, Bild 3 von 3
    • Disconnect the following:
    • Power button cable
    • Speaker cable
    • Power status light cable
    • Bluetooth cable (if installed)
  12. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: Schritt 12, Bild 1 von 1
    • Gently pry off the bracket using the prying tool.
Abschluss
UW Tacoma, Team 1-4, Rose Fall 2016 Mitglied von UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 268
