Zum Hauptinhalt wechseln
Dell Inspiron Mini 10 RAM Replacement
Was du brauchst
  1. Dell Inspiron Mini 10 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 RAM Replacement, WiFi Adapter: Schritt 3, Bild 1 von 2 Dell Inspiron Mini 10 RAM Replacement, WiFi Adapter: Schritt 3, Bild 2 von 2
    • On the bottom of the laptop locate the removable panel and screw holding it to the body. Loosen the screw and take the cover off.
  4. Dell Inspiron Mini 10 RAM Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron Mini 10 RAM Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the black and white antenna cable from the wifi adapter by pinching the gold contacts with the tips of your finger, or you can use tweezers, and pull them straight away from the adapter.
    • Unscrew the single 5mm Phillips 0 screw on the top right of the adapter. The adapter should start to angle away from the body of the computer. Once the screw is off completely, pull the adapter out of the data slot.
  5. Dell Inspiron Mini 10 RAM Replacement, Palm Rest: Schritt 5, Bild 1 von 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  6. Dell Inspiron Mini 10 RAM Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  7. Dell Inspiron Mini 10 RAM Replacement, Keyboard: Schritt 7, Bild 1 von 1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  8. Dell Inspiron Mini 10 RAM Replacement: Schritt 8, Bild 1 von 1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  9. Dell Inspiron Mini 10 RAM Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron Mini 10 RAM Replacement: Schritt 9, Bild 2 von 2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  10. Dell Inspiron Mini 10 RAM Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron Mini 10 RAM Replacement: Schritt 10, Bild 2 von 2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  11. Dell Inspiron Mini 10 RAM Replacement, Palm Rest Bracket: Schritt 11, Bild 1 von 1
    • Close the device and turn over.
    • Remove the five 8mm Phillips 0 screws.
  12. Dell Inspiron Mini 10 RAM Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron Mini 10 RAM Replacement: Schritt 12, Bild 2 von 2
    • Turn the device over and open the display.
    • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
  13. Dell Inspiron Mini 10 RAM Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron Mini 10 RAM Replacement: Schritt 13, Bild 2 von 2
    • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
  14. Dell Inspiron Mini 10 RAM Replacement: Schritt 14, Bild 1 von 2 Dell Inspiron Mini 10 RAM Replacement: Schritt 14, Bild 2 von 2
    • Remove the four 6mm Philips 0 screws securing the bracket.
  15. Dell Inspiron Mini 10 RAM Replacement: Schritt 15, Bild 1 von 3 Dell Inspiron Mini 10 RAM Replacement: Schritt 15, Bild 2 von 3 Dell Inspiron Mini 10 RAM Replacement: Schritt 15, Bild 3 von 3
    • Disconnect the following:
    • Power button cable
    • Speaker cable
    • Power status light cable
    • Bluetooth cable (if installed)
  16. Dell Inspiron Mini 10 RAM Replacement: Schritt 16, Bild 1 von 1
    • Gently pry off the bracket using the prying tool.
  17. Dell Inspiron Mini 10 RAM Replacement, Motherboard: Schritt 17, Bild 1 von 1
    • Remove the following:
    • Two 4mm Phillips screws securing the motherboard
    • AC adapter cable
    • USB and SIM card cable connector
    • Display cable connector
    • Carefully lift the motherboard out.
  18. Dell Inspiron Mini 10 RAM Replacement, RAM: Schritt 18, Bild 1 von 1
    • Turn the motherboard over.
    • Push the clips out on either side of the memory card until it pops up.
    • Remove the memory card.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UW Tacoma, Team 1-4, Rose Fall 2016 Mitglied von UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare zur Anleitung
It is possible to upgrade the memory by simply (!) cutting aq hole in the bottom of the computer case. I used the pictures and Vulcan logic to determine the location and dimensions of the required hole. I used a vibrating saw to cut the hole. You need to be careful not to cut too deep. Once you have a square panel cut out, you need to snip through the copper shield covering the memory card. Then it is a simple in and out replacement. I used a leftover 2 Gig memory card from my MacBook Pro.
Mucheasier than taking out all those screws and connectors!
Paul Vale - Antwort Teilen
Here’s an easier-but riskier- technique. Cut a rectangular hole in the bottom of your Mini 10V. I did it and it worked. Needles to say, you must be careful not to cut too deep! Measure in from the left side (computer shut, upside down and the empty battery compartment away from you) 3/4 inch, and 4.5 inch (from the edge. the lines you draw will be 3.75 inches apart. measure up from the keyboard edge 2.5 inches and 4.75 inches and draw horizontal lines. The ‘box’ you drew is your cutting template. Once inside you need to cut a copper shield to get to the memory card. From that point on it’s easy. I used the 2 gig memory card from my MacBook Pro. When you’re done, glue the panel you cut out back in place and reinsert battery and you’re ready to go. (For cutting the hole, I used a vibrating multi tool with a saw blade)
Disclaimer: Your mileage may vary. If you brick your Mini 10V, you can buy another on Ebay for ~$75.
Good Luck.
Excellent step-by-step graphical explanation makes it look easy by following the instructions congratulations.
heyderbejarano - Antwort Teilen
Not all Mini 10's have upgradable RAM. When I tore mine down, I found there was nothing of interest on the back of the board where the guide says there's a SODIMM slot. Then again, my board seems to be quite different from the one used in this guide: my wireless module was not accessible from the outside but was found underneath the keyboard; my board did not extend all the way to the SD card slot, as that was a separate board connected to the main board by a ribbon cable; and what looked to be a heatsink covering a SODIMM slot turned out to be a daughter board containing the CPU and the RAM together. Mind you, this guide served its purpose in getting my netbook torn all the way down; it simply didn't serve its final intention. The model number for my Mini 10 is PP19S, which happens to have a very colorful shell on the top. If your model number matches mine, save yourself the trouble: the RAM cannot be upgraded conventionally. Then again, if you're comfortable installing surface-mount RAM... :p
Robert B - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 71
Insgesamt: 11,272
