Einleitung
This guide will provide basic information for:
- Replacing components of the device.
- Disassembling the device to reach and repair the touchpad.
- Precautions for preventing further damage.
- Required tools for replacement.
Was du brauchst
Using a spudger, gently pry the palm rest off of the palm rest bracket.
Gently pull the touchpad cable off the palm rest bracket.
Lift the rest of the palm rest off the computer base.
Turn the palm rest assembly over.
Remove the four 3mm Phillips 0 screws that secure the touchpad module to the palm rest.
Gently lift the copper and silver foil squares on the touchpad.
Remove the touchpad from the palm rest.
Abschluss
