Was du brauchst
Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
Gently lift up the keyboard starting at the top of the frame
Make sure that you do not damage the ribbon attached to the bottom of the keyboard
Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
Perform steps one through four in reverse order with your new keyboard to finish the replacement process
4 weitere Nutzer:innen haben diese Anleitung absolviert.
