1. Remove the battery
    • Remove the battery
  2. Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  5. Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Ziellinie
4 weitere Nutzer haben diese Anleitung absolviert.
Marie K Bordley
226 Reputation
2 Anleitungen geschrieben
Ohio State, Team 1-1, Buehl Fall 2014 Mitglied von Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Mitglieder
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 2,702
