Zum Hauptinhalt wechseln
Dell Inspiron Mini 1012 Battery Replacement
  1. Dell Inspiron Mini 1012 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron Mini 1012 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron Mini 1012 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn the device over so the bottom is facing upwards.
    • Slide the two tabs beside the lock icons to the unlocked position.
    • Find the notch located in the center between the two tabs and lift up on the battery to remove it.
    • To replace the battery, align the three notches on the battery with the grooves on the device. Snap the battery back onto the device, and it will lock in place.
Abschluss
To reassemble, place the new battery in the three slots. Lock the battery back in place.
sabinabarajas
387 Reputation
3 Anleitungen geschrieben
Gateway, Team 2-2, Kuhn Fall 2015 Mitglied von Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Mitglied
6 Anleitungen geschrieben
Ein Kommentar
So, I’ve installed the new battery and the mini 1012 won’t recognize or charge it. Now what?
complainingparty - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 1,597
