Zum Hauptinhalt wechseln
Dell Inspiron Mini 1012: Keyboard Replacement
Was du brauchst
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron Mini 1012: Keyboard Replacement: Schritt 3, Bild 2 von 2
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Ziellinie
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ohio State, Team 1-1, Buehl Fall 2014 Mitglied von Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 3,275
