Zum Hauptinhalt wechseln
Dell Inspiron N4010 Top Cover Replacement
Was du brauchst
  1. Dell Inspiron N4010 Top Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Top Cover Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron N4010 Top Cover Replacement: Schritt 2, Bild 2 von 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Top Cover Replacement: Schritt 3, Bild 1 von 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Top Cover Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron N4010 Top Cover Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron N4010 Top Cover Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Top Cover Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Top Cover Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron N4010 Top Cover Replacement: Schritt 7, Bild 2 von 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Top Cover Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron N4010 Top Cover Replacement: Schritt 8, Bild 2 von 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Top Cover Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron N4010 Top Cover Replacement: Schritt 9, Bild 2 von 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
  9. Dell Inspiron N4010 Top Cover Replacement, Top Cover: Schritt 10, Bild 1 von 2 Dell Inspiron N4010 Top Cover Replacement, Top Cover: Schritt 10, Bild 2 von 2
    • Remove the indicated 5.7mm screws.
    • Remove the smaller 3mm screws from underneath the battery compartment.
  10. Dell Inspiron N4010 Top Cover Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron N4010 Top Cover Replacement: Schritt 11, Bild 2 von 2
    • With a plastic spudger, pry away the silver top cover from the black casing.
    • Move the tool to the right and left along the seams to fully disconnect the cover.
  11. Dell Inspiron N4010 Top Cover Replacement: Schritt 12, Bild 1 von 1
    • Disconnect the indicated ribbon cables underneath where the keyboard sits.
  12. Dell Inspiron N4010 Top Cover Replacement: Schritt 13, Bild 1 von 1
    • Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
Abschluss
USF Tampa, Team S13-G5, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 704
