Einleitung
Is your laptop screen cracked or broken? This guide will help you to replace the screen in several easy steps.
Was du brauchst
Locate the battery on the underside of the laptop.
Push the two battery clips following the direction of the arrows.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to peel the webcam away from the top of the laptop.
Lift the adhesive flap from the cord that connects the computer to the screen.
You can then disconnect the cord from the screen.
Eine weitere Person hat diese Anleitung absolviert.
