Zum Hauptinhalt wechseln
Dell Inspiron N5010 Battery Replacement
Was du brauchst
  1. Dell Inspiron N5010 Battery Replacement, Turn Over the Computer: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Shut down the computer and turn it over.
  2. Dell Inspiron N5010 Battery Replacement, Sliding the Battery Latch: Schritt 2, Bild 1 von 1
    • Slide the battery lock latch to the unlock position.
  3. Dell Inspiron N5010 Battery Replacement, Sliding the Battery Latch: Schritt 3, Bild 1 von 1
    • Slide the battery release latch to the side.
  4. Dell Inspiron N5010 Battery Replacement, Lifting the Battery: Schritt 4, Bild 1 von 1
    • Slide and lift the battery out of the battery bay.
  5. Dell Inspiron N5010 Battery Replacement, Align the Tabs: Schritt 5, Bild 1 von 1
    • Align the tabs on the NEW battery with the slots on the battery bay.
  6. Dell Inspiron N5010 Battery Replacement, Sliding the Battery: Schritt 6, Bild 1 von 1
    • Slide the battery into the battery bay until it clicks into place.
  7. Dell Inspiron N5010 Battery Replacement, Sliding the Lock Latch: Schritt 7, Bild 1 von 1
    • Slide the battery lock latch to the lock position.
Ziellinie
Terrence15
79.243 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 1,194
