Einleitung
If your disk drive on your Dell Inspiron N5030 is not working, and you have tried the other options on the troubleshooting page, this guide will help you replace it with a new one.
Was du brauchst
Turn the computer over on its back so the battery compartment faces towards you.
Place your fingers on the small buttons with arrows pointing outwards.
Push and slide the buttons outward to unlock the battery compartment.
Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
Position your thumbs to push firmly and slide the disc drive to the right through the rectangular hole in the side of the laptop and out.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
