Zum Hauptinhalt wechseln
Dell Inspiron N5030 RAM Replacement
Was du brauchst
  1. Dell Inspiron N5030 RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron N5030 RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 RAM Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron N5030 RAM Replacement: Schritt 2, Bild 2 von 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 RAM Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 RAM Replacement: Schritt 4, Bild 1 von 1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 RAM Replacement: Schritt 5, Bild 1 von 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 RAM Replacement: Schritt 6, Bild 1 von 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 RAM Replacement: Schritt 7, Bild 1 von 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 RAM Replacement: Schritt 8, Bild 1 von 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 RAM Replacement: Schritt 9, Bild 1 von 1
    • Remove the top keyboard panel.
  10. Dell Inspiron N5030 RAM Replacement, RAM: Schritt 10, Bild 1 von 1
    • Place your fingers on the two metal tabs on the edges of the RAM.
    • Push on the tabs in the opposite direction.
    • The top RAM board will pop up after you push on the metal tabs.
  11. Dell Inspiron N5030 RAM Replacement: Schritt 11, Bild 1 von 1
    • Pull the top RAM board out with your fingers.
  12. Dell Inspiron N5030 RAM Replacement: Schritt 12, Bild 1 von 3 Dell Inspiron N5030 RAM Replacement: Schritt 12, Bild 2 von 3 Dell Inspiron N5030 RAM Replacement: Schritt 12, Bild 3 von 3
    • Repeat the above RAM board steps for the second RAM board.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 10-59, Amido Spring 2014 Mitglied von Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
swestonj - Antwort
swestonj is incorrect. The manual clearly states that you must remove the screws:
Service Manual
Removing the Keyboard
1. Follow the instructions in Before You Begin.
2. Remove the battery (see Removing the Battery).
3. Remove the two screws that secure the keyboard to the computer base.
etc.
mike -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 5,390
