Zum Hauptinhalt wechseln
Dell Inspiron N5050 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron N5050 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron N5050 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron N5050 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 Hard Drive Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron N5050 Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Unscrew the two palmrest screws.
    • Lift the two, blue palmrest cables up and out of their sockets.
  8. Dell Inspiron N5050 Hard Drive Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron N5050 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Lift the entire surface (palmrest casing) to expose the motherboard underneath.
  9. Dell Inspiron N5050 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Slide the hard drive right and up to remove it from the laptop.
Abschluss
11 weitere Personen haben diese Anleitung absolviert.
Kristy Mayo
1.508 Reputation
3 Anleitungen geschrieben
4 Kommentare
Thanks again. This guide was made straightforward and clear.
jason acn - Antwort
Thanks you - The clear instructions make this guide easy to follow.
Jay - Antwort
wouldnt turn on after i re-assembled it
Taemon Coolz - Antwort
Sehr gute Arbeit
pouchman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 37
Insgesamt: 7,061
