Einleitung
WiFi & Blue-tooth mini PCI card replacement. To change the Wifi card on this model you must to remove the upper case of the laptop. This is not a good engineering designee. We will show you how to do this.
Was du brauchst
Einführungsvideo
Switch off the laptop and remove the battery.
The keyboard is held by 4x locking clips.
By using cutter, carefully lift up the one side of the keyboard and start opening the locking clips.
Disconnect the keyboard cable and remove the keyboard.
Remove the access door screw and the access door
Remove the screw securing the optical drive, and remove the optical drive
Here is the Wi-Fi card
Disconnect the antenna cable connectors
Remove the Wi-Fi card
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Great, cogent step by step. You alleviated the need to watch a video while including all of the key steps. Nicely done. I replaced a hard drive last year and I would have preferred this format.
Hi, do you know if there is a whitelist for wifi adapters in this notebook?
