Zum Hauptinhalt wechseln
Dell Inspiron i3558-5500BLK Back Cover Replacement
Was du brauchst
  1. Dell Inspiron i3558-5500BLK Back Cover Replacement, Keyboard: Schritt 1, Bild 1 von 2 Dell Inspiron i3558-5500BLK Back Cover Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 2, Bild 3 von 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: Schritt 3, Bild 1 von 3 Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: Schritt 3, Bild 2 von 3 Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: Schritt 3, Bild 3 von 3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Back Cover Replacement, Back Cover: Schritt 4, Bild 1 von 2 Dell Inspiron i3558-5500BLK Back Cover Replacement, Back Cover: Schritt 4, Bild 2 von 2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 5, Bild 2 von 2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 6, Bild 3 von 3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron i3558-5500BLK Back Cover Replacement: Schritt 7, Bild 2 von 2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nathan Ybanez
622 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S9-G5, Banghart Fall 2017 Mitglied von Cal Poly, Team S9-G5, Banghart Fall 2017
CPSU-BANGHART-F17S9G5
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,083
