Zum Hauptinhalt wechseln
Dell Inspiron n5050 RAM Replacement
Was du brauchst
  1. Dell Inspiron n5050 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 RAM Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron n5050 RAM Replacement: Schritt 3, Bild 2 von 2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 RAM Replacement, Keyboard: Schritt 4, Bild 1 von 2 Dell Inspiron n5050 RAM Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 RAM Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron n5050 RAM Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron n5050 RAM Replacement: Schritt 5, Bild 3 von 3
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
  6. Dell Inspiron n5050 RAM Replacement, RAM: Schritt 6, Bild 1 von 3 Dell Inspiron n5050 RAM Replacement, RAM: Schritt 6, Bild 2 von 3 Dell Inspiron n5050 RAM Replacement, RAM: Schritt 6, Bild 3 von 3
    • Locate RAM
    • Push outwards on both retaining clips, the RAM will pop up slightly when it is free from the clips.
  7. Dell Inspiron n5050 RAM Replacement: Schritt 7, Bild 1 von 1
    • The RAM will pop up, and then you can slide it out at the same angle it is at.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Tyler
5.031 Reputation
16 Anleitungen geschrieben
TechForce Mitglied von TechForce
Business
2 Mitglieder
29 Anleitungen geschrieben
Ein Kommentar
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 10,417
