Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Remove the two screws that secure the display assembly to the computer base.
Disconnect the display cable and touch-screen cable from the system-board connectors.
Note the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
Remove the four screws that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Route the Mini-Card antenna cables through the routing guides.
Connect the display cable and touch-screen cable to the connectors on the system board.
Replace the two screws that secure the display assembly to the computer base.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
