Einleitung
Keycaps can become sticky or damaged over time. Here is how to remove and replace large sized keycaps, like the space bar.
Was du brauchst
Place the prongs on either side of the keycap
Twist to grip the top and bottom corners
Pull the keycap from the board
Insert the flat end of the spudger under the medium keycap and gently press up until it pops off
After removing the medium keycaps around the large keycap, gently pull up on the large keycap
