1. Remove the battery  from the laptop.
    • Remove the battery from the laptop.
    • Remove the RAM access panel screw.
  2. Remove the RAM access  panel. Unlock the RAM  retainer clips on each side of the module.
    • Remove the RAM access panel. Unlock the RAM retainer clips on each side of the module.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Be sure to organize the screws, as they are various different sizes!
    • Be sure to organize the screws, as they are various different sizes!
    • Remove the RAM module. .Insert the RAM into the RAM slot. Place the RAM access panel over the installed RAM module.
  5. Remove the HDD access  panel screw.
    • Remove the HDD access panel screw.
    • Remove the HDD from the laptop.
    • Place the HDD access panel on the HDD.
    • Install the HDD in the laptop. Retrieve the HDD access panel screw from the antistatic mat
  6. Insert wisdom here.
    • Insert wisdom here.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Amal
155 Reputation
1 Anleitung geschrieben
laptop repair clinic 2 Mitglied von laptop repair clinic 2
Community
4 Mitglieder
مبدعات
ولكن اين الشرح ؟
Sara Almutairi - Antwort
تم كتابة الخطوات :)
Amal -
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 758
