Einleitung
We're going to teach you how to remove the charging port.
Was du brauchst
Remove the backplate of the tablet by using the plastic opening tool to lift it up.
Using a JIS #00 screwdriver, remove the two 4.0mm screws securing it to the motherboard.
Lift up the orange clamp connecting the black DOC B/D cable to the charging board.
Place the opening tool underneath the charging board, lift up, and slide it out the charging port, along with its board.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
