Einleitung
We're going teach you how to remove the front facing camera from the Dell Latitude 10-ST2e.
Was du brauchst
Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
Using a JIS #00 screwdriver, remove the one 4.0mm screw securing the camera to the motherboard.
Gently lift up the camera using the plastic opening tool and remove it from the tablet.
