Einleitung
We're going teach you how to remove the front facing camera from the Dell Latitude 10-ST2e.
Was du brauchst
Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
Using a JIS #00 screwdriver, remove the one 4.0mm screw securing the camera to the motherboard.
Use an opening tool to release the black clamp. With the tweezers gently lift and disconnect the motherboad from the camera.
Gently lift up the camera using the plastic opening tool and remove it from the tablet.
