Einleitung
The trackpad of your laptop is a touch-sensitive surface used to communicate with the laptop to move the cursor on your screen. If you are not getting an on-screen response from your Dell Latitude 3189 when you interact with the trackpad, you may need to replace the trackpad to resolve the issue.
The cable connector can damage easily, be careful when moving the ribbon as to not break the connector socket.
You will need to reference the base cover replacement guide to remove the base cover from your device before continuing to the rest of this guide. Make sure that your device is completely powered off before using this guide.
Was du brauchst
Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
Flip up the white ZIF lock bar on the trackpad motherboard socket.
Gently pull the ribbon cable directly out of its motherboard socket.
Use a Phillips #1 screwdriver to remove the following screws:
Six 2.4 mm screws
The single 3.6 mm screw
