Einleitung
Follow this guide if the keyboard in your Dell Latitude 3190 has stopped functioning.
Make sure your device is powered off and unplugged from external power before beginning the repair.
Ersatzteile
Keine Ersatzteile angegeben.
Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
Lift the bottom cover from the laptop.
Disconnect the battery cable located on the top of the battery.
Use the spudger and disconnect the battery cable.
Pull the cable out of the way.
Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
Use the spudger to release the small black tab locking down the connector by lightly pushing up on it.
Disconnect the keyboard cable from the connector on the system board.
Hold down the laptop securely while pushing into the two release holes using a spudger.
Turn the laptop over, so the keyboard is facing up
Pry the bottom of the keyboard using a spudger to the release the keyboard.
Slide the keyboard outwards, away from the computer, and lift the keyboard away from the computer.
