Einleitung
If you need to replace or upgrade your M.2 SSD for the Dell Latitude 3190, follow this guide.
Before starting this repair, power off your device and unplug from the charger.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
Lift the bottom cover from the laptop.
Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
Locate the M.2 SSD after the battery is removed
Use the Phillips #0 screwdriver to remove the 3 mm screw from the SSD.
Pull the M.2 SSD from the board.
