Einleitung
Remove and replace the power switch board of your Dell Latitude 3190 if your power button and/or volume buttons no longer work properly.
Ersatzteile
Keine Ersatzteile angegeben.
Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
Lift the bottom cover from the laptop.
Disconnect the battery cable located on the top of the battery.
Use the spudger and disconnect the battery cable.
Pull the cable out of the way.
Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
