Einleitung
In this guide, we will be going over the process of replacing the speakers on the Dell Latitude 3380. It is a simple process that only requires a few steps.
The speakers function as a way for audio to be played while using the laptop. They are used for anything from music to watching videos online.
Was du brauchst
Turn the laptop over so that the back is facing up.
Remove the nine 3 mm screws with a Phillips #0 screwdriver.
Using the nylon spudger, pry off the velcro straps attaching the cable to the chassis.
Using the spudger, pry off the other velcro strap attaching the power cable to the chassis.
They will be attached via velcro to it so you should have some resistance. This is normal.
