Was du brauchst
10 screws hold the bottom cover in place -- these stay in the bottom cover.
Using a spudger will make quick work of this step.
Disconnect the battery cable from the motherboard.
Remove the 4 screws holding it in place
Battery can now be removed from device.
Unplug the fan header
Unplug the VGA board cable
Unplug the LCD cable
Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
Loosen the 7 screws in sequential order as labeled on the heatsink [1, 2, 3, 4, 5, 6, 7]
Lift heatsink out of device
To replace these screws: place the heatsink, line up the screw holes, then tighten the screws in the same sequential order labeled on the heatsink.
Carefully remove the two antennas from their slots.
The card should slide right out for easy replacement.
Two clamps hold the RAM module in place, once these are moved the module will slide out of the slot and can be replaced.
8 remaining connections: IO Board, VGA Board, power button board, display ribbon, touchpad, keyboard, speakers, and PWR.
