Was du brauchst
10 screws hold the bottom cover in place -- these stay in the bottom cover.
Using a spudger will make quick work of this step.
Disconnect the battery cable from the motherboard.
Remove the 4 screws holding it in place
Battery can now be removed from device.
Carefully remove the two antennas from their slots.
The card should slide right out for easy replacement.
Fast fertig!
Abschluss
