Zum Hauptinhalt wechseln
Dell Latitude 3520 Battery Replacement
Was du brauchst
  1. Dell Latitude 3520 Battery Replacement, Remove MicroSD-card: Schritt 1, Bild 1 von 1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 Battery Replacement, Bottom Case: Schritt 2, Bild 1 von 3 Dell Latitude 3520 Battery Replacement, Bottom Case: Schritt 2, Bild 2 von 3 Dell Latitude 3520 Battery Replacement, Bottom Case: Schritt 2, Bild 3 von 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Slide the metal above the connector on the battery to unlock.
  4. Dell Latitude 3520 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Latitude 3520 Battery Replacement: Schritt 4, Bild 2 von 2
    • Peel the adhesive tapes and the battery cable.
  5. Dell Latitude 3520 Battery Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery cable from the connector on the system board.
  6. Dell Latitude 3520 Battery Replacement: Schritt 6, Bild 1 von 2 Dell Latitude 3520 Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  7. Dell Latitude 3520 Battery Replacement: Schritt 7, Bild 1 von 1
    • Lift and remove the battery.
Abschluss
Shawn Smith
871 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 42
Letzte 30 Tage: 138
Insgesamt: 796
