Zum Hauptinhalt wechseln
Dell Latitude 3520 Screen Replacement
Was du brauchst
  1. Dell Latitude 3520 Screen Replacement, Remove MicroSD-card: Schritt 1, Bild 1 von 1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 Screen Replacement, Bottom Case: Schritt 2, Bild 1 von 3 Dell Latitude 3520 Screen Replacement, Bottom Case: Schritt 2, Bild 2 von 3 Dell Latitude 3520 Screen Replacement, Bottom Case: Schritt 2, Bild 3 von 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 Screen Replacement, Screen Removal: Schritt 3, Bild 1 von 3 Dell Latitude 3520 Screen Replacement, Screen Removal: Schritt 3, Bild 2 von 3 Dell Latitude 3520 Screen Replacement, Screen Removal: Schritt 3, Bild 3 von 3
    • Remove the 2mm Phillip #0 screw that secures the WLAN card bracket to the WLAN card on the system board.
    • Lift and remove the WLAN card bracket from the WLAN card that secures the two antenna cables.
    • Disconnect the antenna cables from the connectors on the WLAN card.
    • Disconnect and remove the WLAN card from the WLAN card slot.
  4. Dell Latitude 3520 Screen Replacement: Schritt 4, Bild 1 von 3 Dell Latitude 3520 Screen Replacement: Schritt 4, Bild 2 von 3 Dell Latitude 3520 Screen Replacement: Schritt 4, Bild 3 von 3
    • Peel the adhesive tape, open the latch, and disconnect the I/O cable from the connector on the system board.
    • Lift and remove the I/O cable from the assembly.
  5. Dell Latitude 3520 Screen Replacement: Schritt 5, Bild 1 von 1
    • Unroute the display cable from the routing guides in the assembly.
    • Peel the adhesive tape that secures the display cable in place.
  6. Dell Latitude 3520 Screen Replacement: Schritt 6, Bild 1 von 3 Dell Latitude 3520 Screen Replacement: Schritt 6, Bild 2 von 3 Dell Latitude 3520 Screen Replacement: Schritt 6, Bild 3 von 3
    • Remove the one 4.55mm Phillip # 0 screw and six 2.5mm Phillip #0 screws that secure the display hinges to the system.
  7. Dell Latitude 3520 Screen Replacement: Schritt 7, Bild 1 von 1
    • Lift the left and right hinges in an upward direction away from the assembly.
  8. Dell Latitude 3520 Screen Replacement: Schritt 8, Bild 1 von 1
    • Lift the assembly off the display assembly.
Abschluss
Shawn Smith
871 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 33
Letzte 30 Tage: 131
Insgesamt: 613
